Breach growth formula (Water Overlay)
Water can flow through breaches into levee protected areas. These breaches often start small and grow over time[1].
The water flowing through breaches can originate from an external area outside the project area or an input area within the project area.
First, the difference in height of the water on either side of the breach is calculated.
Using the height difference, the breach width increase is calculated.
The current breach width is then equal to the last calculated breach width, plus the calculated breach width increment.
- Wb,t = Wb,t-1 + ΔWb,t
Where:
- Wb = The BREACH_WIDTH of the breach.
- Hb,t = The BREACH_HEIGHT of the breach at time t.
- Wb,t = The calculated breach width, initially equal to Wb.
- wb,t = water level at breach at time t.
- we,t = water level at entry area (external or internal) at time t.
- Δht = The difference between the height of the water columns on either side of the breach at time t.
- fm = Material factor, set to 1.3 (average for sand and clay levees).
- g = Acceleration factor of GRAVITY, defined for the Water Overlay.
- csb = The critical BREACH_SPEED of the breach.
- ΔWb,t = The calculated width increase of the breach at time t.
- The breach height Hb,t can be defined over time, by configuring the BREACH_HEIGHT as an attribute array.
Related
- Features
- Breach
- Formulas
- Breach flow formula
- Models
- Surface model
- ↑ Verheij, H.J. ∙ Aanpassen van het bresgroeimodel in HIS-OM: Bureaustudie ∙ found at: http://resolver.tudelft.nl/uuid:aedc8109-da43-4a03-90c3-44f706037774 ∙ (last visited 2019-03-08)
