Inlet formula (Water Overlay)
Revision as of 10:02, 17 October 2019 by Frank@tygron.nl (talk | contribs)
Inlets are hydraulic structures can pump water in and out of the project area and are connected with a water body outside the project area.
Case 1: Inlet:
If a lower threshold Tl,t is defined:
Qlth=max(0,Tl,twt)
If a positive inlet q Qt is defined:
Qt=ΔtQt
If a capacity Qtotal is defined:
Qc = Qtotal- ΣQ0..t-1
After calculating the capacities, the actual water inflow is calculated. If any of the terms are undefined, they are not included.
Δw = max( 0 , min( Qlth , Qt , Qc ) ) / A
Case 2 Outlets:
If an upper threshold Tu,t is defined:
Quth = min( 0 , Tu,t - wt )
If a negative inlet q Qt is defined:
Qt = Δt * Qt
Qc = -Qtotal - ΣQ0..t-1
After calculating the capacities, the actual water ouflow is calculated. If any of the terms are undefined, they are not included.
Δw = min( 0 , max( Quth , Qt , Qc) ) / A
Where:
  • Q0..n = The calculated previous amounts of flow.
  • Qlth = The desired lower water level at the inlet's location, based on the LOWER_THRESHOLD of the inlet.
  • Quth = The desired upper water level at the outlet's location, based on the outlet's UPPER_THRESHOLD of the inlet.
  • Qt = The amount of water inflow (or outflow when negative) possible based on the INLET_Q of the inlet and timestep Δt.
  • Qc = The total amount of water inflow (or outflow when negative) allowed based on the total capacity of the inlet.
  • A = Size of the inlet/outlet area in m2, based on the amount of cells and cell size. Current implementation only has one cell.
Related
Structures
Inlet
Models
Surface model
Template:WaterOverlay nav
