Angle
Revision as of 11:48, 20 December 2019 by Rudolf@tygron.nl (talk | contribs)
This article is a stub.
The angle from the horizontal plane. For lines or directions, 0 means flat across the horizontal plane, a positive value means the angle directs up, and negative angle directs down. For inclines, 0 means a perfectly flat surface, and the higher the angle the steeper the surface.
Value Cardinal direction
Flat on the horizontal plane
90° Straight up, perpendicular to the horizontal plane
-90° Straight down, perpendicular to the horizontal plane
