How to create a parametric design
This article is a stub.
How to create and use a parametric design:
- Create a new parametric design.
- Select the desired design type.
- Select the desired function.
- Select the desired floors.
- Draw the extent in the 3D world.
- Set the desired surface area and distance. Balance them.
- Verify that the selections in the 3D world look appropriate. If not, tweak the configuration further.
- Apply the design.
- Verify that the result looks appropriate. If not, revert the application and tweak the configuration further.
