Demo Heat FAQ & More
| <<Previous page | <<<Back to start |
FAQ
- What is the Bowen Ratio?
- The Bowen Ratio is the ratio between sensible and latent heating during heat transfer from a (moist) surface to its environment. This ratio is described by the following equation: Bowen ratio = sensible heat/ latent heat,
See also: https://en.wikipedia.org/wiki/Bowen_ratio
- What is the Foliage Crown Factor?
- The Foliage Crown Factor is used for calculating the foliage extent of trees. This is more accurate than only using the extent of tree trunks. By applying the Foliage Crown Factor, these tree trunks are transposed into foliage crown extents, which are then used for Heat Stress calculations.
See also:Foliage Crown Factor
Support
In case you need further assistance or extra information in implementing the techniques from this tutorial, we have the following support options for all our users available:
Want more?
If you would like to do more with the Tygron Platform, please upgrade your trial license to Bronze (or higher).
