Version 2019
Revision as of 10:08, 18 March 2020 by Frank@tygron.nl (talk | contribs) (Created page with "==Version 2019.1.0== {{:Version_2019.1.0}} ==Version 2019.1.1== {{:Version_2019.1.1}} ==Version 2019.2.0== {{:Version_2019.2.0}} ==Version 2019.3.0== {{:Version_2019.3.0}} ==V...")
Version 2019.1.0
Version 2019.1.0 is released on preview.tygron.com (Preview) on Friday November 2, 2018
Geo
  • Improved performance when loading large maps.
  • Fixed several missing BRO types for underground.
Water Overlay
  • Culverts are now defined by their width and manning roughness.
  • Culverts can also have a flow-in threshold height.
  • Some small improvements to the Wizard Interface, e.g. improved sorting of areas.
  • Water areas are now prioritized, e.g. when overlapping, breaches go before water areas.
  • Some small fixes in the groundwater & chemical flow.
API & Networking
  • New API support for the smile protocol (binary json).
  • Dynamic compression in combination with smile improves download speed and locking time.
  • New location for general API events preview.tygron.com/api
  • Domain admins can see their active Sessions at preview.tygron.com/api/sessions
  • JavaScript API interaction now possible in Community Panels.
Several small changes and bug fixes
  • Bugfix for facilitators closing a session.
  • Timeframe setting bug.
Version 2019.1.1
Version 2019.1.1 is released on preview.tygron.com (Preview) on Friday November 9, 2018
Grid Overlays
  • Max cell amount increased from 100 million to 1 billion grid cells.
  • Minimum of 100 timeframes for overlays.
  • New GPU Cluster added for more calculation capacity.
Water Overlay
  • Improved usability of WaterOverlay's timeframe sliders.
  • Improved water on slope calculations for Groundwater Waterbalance results.
  • Improved efficiency and performance of GridOverlay calculations, especially on large grids.
DEM
  • Fixed a bug where manually raising and lowering the DEM did not actually change any heights.
API
  • Added parameter indexes in API Event pages and InputException messages, such that users are informed which provided parameter was wrong.
General bugfixes
  • Fixed enabling grid exports in the Editor during test runs.
  • Fixed creating new empty projects using templates.
  • Fixed generating difference legend when normal legend was already customized.
  • Fixed login ip blocks on wrong passwords.
Version 2019.2.0
Version 2019.2.0 is released on preview.tygron.com (Preview) on Thursday November 29, 2018
GUI
  • New Measurement Tool panel to measure Overlay data. Both Point and Line data can be shown.
  • New Performance panel shows details how long it takes to recalculate the Overlays, Indicators, etc.
  • Redo layout of Editor, focused on the current situation, future and multi stakeholder.
  • Only show relevant GUI panels for these three focus areas.
Performance
  • Improved performance for large amount of TQL update Queries.
  • Improved performance for Grid based TQL Queries.
  • Better load sharing between Projects running at the same time.
Water Overlay
  • Improved visualisation of Direction Overlay.
  • Improved processing time of Wateroverlay with multiple Timeframes.
  • Improved handling of Timeframe Overlays in GUI.
API
  • Added Documentation for multiple events.
Known Issues
  • Future Tab needs extra work (e.g. no Stakeholder selection here).
  • Measurement Tool is in Beta and needs more testing.
Version 2019.3.0
Version 2019.3.0 is released on preview.tygron.com (Preview) on Thursday Dec 20th 2018
Water
  • Performance improvement for ground water.
  • Improved water flow stability around edges and shorelines.
  • New option to set both lower and upper thresholds on Breach Areas that trigger the in/outlet to become active.
  • Breach Area's FLOOR_LEVEL_M has been renamed to SURFACE_OVERRIDE. Conceptually, it can also be used to raise land, with our without water flowing in and out.
  • Water areas now only define the Water Level in an area. Inlet Objects can be added as (underground) buildings.
  • A negative value for Inlet behaves as an Outlet.
  • A Lower Threshold can be set to limit the amount of water added by the Inlet.
  • An Upper Threshold can be set to limit the amount of water removed by an Outlet.
  • Both Thresholds are optional.
  • Outlets are now correctly named Inlet (positive values).
Interface
  • Renamed Dike to Levee.
  • Bugfixes for Measurement Tool.
  • Measurement Tool shows distance in meters and had start/end color dots.
  • Measurement Tool flies to old location when selecting a previous Measurement.
  • Ability to drag in GeoTIFF files.
TQL
  • Support more Color Queries (e.g. network lines).
  • Support for is active on Overlays and Indicators.
SDK
  • Removed all JavaFX code from Developer SDK, Java 11 compatible now.
Known Issues
  • Groundwater is still in BETA (experimental) it has not been thoroughly tested.
Version 2019.3.1
Version 2019.3.1 is released on preview.tygron.com (Preview) on Thursday Jan 17th 2019.
General bugfixes
  • Fixed an issue where SSL Certificates of certain GEO Servers where not recognized.
  • Updated the GML version to accommodate updated PDOK Sources.
Water
  • Limit max timeframes to both grid size and (child) overlays.
Interface
  • Update to new Preview WIKI location.
Version 2019.3.2
Version 2019.3.2 is released on preview.tygron.com (Preview) on Friday Jan 18th 2019.
GPU
  • Limited GPU Calculation time to 1 hour during business hours 8-18 (Amsterdam Timezone).
  • Limited GPU Calculation time for off hours to the start of the next work day (or 1 hour).
Interface
  • GPU Calculation tab (upper left in editor) shows your local timezone business hours and available max calculation time.
  • When your calculation takes longer then the timeout value a warning is displayed in the view screen.
Version 2019.4.0
Version 2019.4.0 is released on preview.tygron.com (Preview) on Thursday Jan 31th 2019
Water
  • Breach Growth: This is a new feature that replaces the old breaches. It can also grow the breach in size over time.
  • Weir: Dynamic switching to submerged weir flow when needed.
  • Weir: Option to change the weir's height over time. E.g. a winter and summer level.
  • Several small bug fixes related to extreme values and small round-offs in e.g. inlets and groundwater.
Overlays
  • Traffic Noise overlay is 5x faster and new option to set the background noise.
  • Traffic Noise distance limit (how far sound can travel) is upgraded from 500m to 2000m.
  • Both Sight Distance and NO2 Overlay are also 5 times faster.
  • Attributes for Items (Buildings, Areas, Indicators, Neighborhoods, etc) can now have both single an multiple values.
  • Option in menu to set the amount of max decimals an attribute can take.
  • Color attributes now accept both single value notation and 3/4 values RGB(A).
  • Excel Library is updated for the new Excel features (e.g. areas) and improved performance.
Performance & Stability
  • Peak hours allow up to 1 hour calculation, you can automatically schedule an update to off-hours for longer calculations.
  • Large Projects are saved faster to disk, preventing long freezing projects.
  • Updated underlying Geo Libraries and GPU Drivers for improved performance and compatibility.
API
  • Implemented a new naming convention for Editor Events. This improves consistency and readability.
  • Most e.g. REMOVE events now support both single value and multi value (e.g. delete an entire array of buildings).
  • Net Line Definition is now called Net Function for consistency reasons.
Version 2019.4.1
Version 2019.4.1 is released on preview.tygron.com (Preview) on Friday Feb 8th 2019
Traffic Noise
  • Threshold lowered from 40 dB to 35 dB.
Water
  • Bugfix for horizontal groundwater speed.
Version 2019.5.0
Version 2019.5.0 is released on preview.tygron.com (Preview) on Friday March 1st 2019
Groundwater Overlay
  • Benchmarked and validated the subsurface flow.
  • Subsurface flow can flow in multiple directions; removes small artefacts.
  • Water quality has more generic naming; substance A,B,C,D.
Rain & Flood Overlay
  • 5-6 times faster updates for Water Overlays, based on new Quad Cell algorithm and other GPU optimizations.
  • Improved loading of the surface elevation model into the GPU, resulting improved accuracy.
  • Option to add a flow angle for the Breach, resulting in more realistic breaches.
Other
  • Beta for Tygron Index to share Indicator Excels more easily between users.
  • Sub domains can also have a maximum amount of Projects and map size.
Version 2019.5.1
Version 2019.5.1 is a small update released on preview.tygron.com (Preview) on Tuesday March 5th 2019
  • Improved Stability around deep water areas.
  • Mouse wheel can be used to scroll through timeframes in the Editor Wateroverlay time graph.
Version 2019.5.2
Version 2019.5.2 is a small update released on preview.tygron.com (Preview) on Friday March 8th 2019
  • Fixed speed overlay artifact.
  • Water objects (weirs, culverts, inlets, etc) are now selectable in the editor building panel.
  • Water objects (weirs, culverts, inlets, etc) now lower the DEM to the lowest neighbouring cell value, this improves connectivity with the water area.
  • Attribute MAX_SPEED_MS has been removed, this variable is calculated by the model, no need to set it anymore.
Version 2019.5.3
Version 2019.5.3 is a small update released on preview.tygron.com (Preview) on Friday March 15th 2019
  • Filter invalid water object values, e.g. negative weir width.
  • Measurement tool can have two overlays now.
  • Measurement tool lines are interpolated resulting in smoother graphs.
  • The levee tool supports relative heights and can replace the original function, resulting in e.g. a road lowering of 10cm.
  • Geo Wizard can import waterways from a polygon collection.
  • The Water model DEM is adjusted to compensate for small waterways.
  • Aquifer Areas can now also have a bottom height, useful for drains at a specific depth.
  • The rainfall can be limited to a smaller area.
  • Added gravity as adjustable attribute.
Version 2019.6.0
Version 2019.6.0 was released on preview.tygron.com (Preview) on Wednesday March 27th 2019
Water Overlay
  • Improved calculation speed for large amount of culverts (1000+).
  • Breach Areas can now also have an input area.
  • Pumps have the same functionality as outlets.
  • Pumps flow from low water area start level to high water area start level. In case of no water areas fallback is to surface height.
  • Option to lower all waterways using attribute MAX_WATER_BOTTOM_M.
API
  • Improved documentation around overlay queries using a Bounding Box.
  • All API queries now support setting a different CRS (e.g. Amersfoort) for input/output values.
  • Items lists can be queried using version and Bounding Box.
  • Default CRS is now: Pseudo-Mercator (EPSG 3857).
  • Improved consistency of event naming.
User Interface
  • Updated several icons/images for editor functionality and overlays.
  • Start menu provides getting started movies.
  • Measurement size tweaked for smaller screen sizes and several related bugfixes.
  • Improved Terrain Height import wizard.
Version 2019.6.1
Version 2019.6.1 was released on preview.tygron.com (Preview) on Friday March 29th 2019
Measures
  • Levees can be activated directly from a measure: e.g. increase or lower road height.
  • Measure itself can be activated directly from editor panel.
Water
  • Bugfix for setting initial groundwater depth via GeoTiff.
  • Pump Upper Threshold and Lower Threshold have been reimplemented to work on the correct entry locations. The Upper Threshold now works on the upper entry of the Pump and the Lower Threshold works on the lower entry of the Pump. Furthermore, their behavior is now also dependent on the direction of the Pump Speed.
API
  • All Attributes of functions are now visible in the API.
User Interface
  • Permission popups are disabled by default for new projects.
  • Editor Tab colors red when test run is still active in another tab.
  • Last left panel in tab remains active for faster switching between functionality.
  • Community Hub link remains accessible during test runs.
  • Added notification for downloading Debug excels of Indicators that have not yet been calculated.
  • Improved tab switching speed in Community Hub.
Version 2019.7.0
Version 2019.7.0 was released on preview.tygron.com (Preview) on Friday May 3th 2019
Water
  • The wiki documentation on Water Module has been updated
  • Improved documentation links in the Water Overlay Wizards
  • Minor bugfixes
UI
  • Measurements panel: fixed saving csv's
  • Fixed Level ordering
  • Minor bugfixes
Version 2019.7.1
Version 2019.7.1 was released on preview.tygron.com (Preview) on Tuesday May 7th 2019
Bugfixes
  • Bugfix for Weir, Pump, Inlet variable values when simulation time is longer then 3 hours.
  • Bugfix for Zoning Plugin: updated the Ruimtelijke Plannen URL to new location.
  • Bugfix for small evaporation values over longer periods resulting in an invalid Water Balance.
  • Bugfix for resetting unused sessions while in testrun mode.
  • Several smaller Interface bugs.
Version 2019.7.2
Version 2019.7.2 was released on preview.tygron.com (Preview) on Thursday May 9th 2019
Bugfixes
  • Client can now (re)connect to session that is still calculating.
  • Improved error logging when session fails to start.
  • GPU Job queue length is limited to memory size.
  • Amount of inactive overlays is now limited to 50.
User Interface
  • Limit rain to active project area settable in wizard.
  • Low Impulse Mode settable in editor water panel.
  • Several WIKI integration fixes.
  • Several small bugfixes.
Version 2019.7.3
Version 2019.7.3 was released on preview.tygron.com (Preview) on Friday May 17th 2019
Water
  • Improved Wizard feedback on how to correctly setup the thresholds for in- and outlets.
  • When a height is provided for the culvert this value is also used to adjust the underlying DEM. Prevents "sunken culvert" issue. Maximum distance between land and culvert for this to work is set using the attribute CULVERT_DEM_THRESHOLD_M, default 10m.
  • Bugfix for incorrect water balance when the breach area polygon is incorrect.
  • Bugfix for incorrect water balance when a sewer overflow was not connected to a sewer.
  • Fixed several smaller issues in Subsidence Overlay.
  • Fixed issue where water structures are incorrectly set when data changes.
  • Fixed issue Waterbalance panel was not always visible.
User Interface
  • 2D webviewer updates for measures/building changes.
  • Fixed ESRI login screen.
  • Fixed Forum auto login.
  • Added cancel button to movie render panel.
  • Several small bugfixes, layout improvements and textual changes.
Open Street Maps
  • Linked more existing OSM data to functions and terrains.
  • Fixed issue where polygons for large OSM relation, such as water and riverbanks, were not correctly converted and constructed.
Other
  • Improved API feedback for incorrect events.
  • Exported GeoJSON now follow the standard definition.
  • Train station is no longer a landmark function.
  • Save As cannot create a corrupt unsaved project.
  • Improved handling of Not a Number (Nan) values in GeoTiffs.
  • Added simple train model on railways.
  • Reset passwords no longer contain difficult characters (e.g. i,1,I).
Version 2019.7.4
Version 2019.7.4 was released on preview.tygron.com (Preview) on Friday May 24th 2019
Water
  • Added warning when culvert, inlet, etc is not correctly positioned.
  • Increased cycle limit, could become issues for long running simulations.
Project generation
  • Fixed issue in Dutch Kadaster layer in which not always all plots were correctly retrieved.
  • Improved railway visualization.
  • Imported asset images are auto-scaled to correct value.
  • Less strict filename checking (auto corrected for invalid characters).
Networks
  • Fixed several client issues with network editing.
  • Fixed issue in importing networks using json files.
  • Improved network wizard and added default excel template.
Overlays
  • Added documentation button with more info.
API
  • More api feedback added for overlay legends.
  • API is less strict for names, e.g. project names may have capitals now.
  • API provides more feedback about invalid events fired.
Bugfixes
  • Invalid characters (e.g. specific Chinese signs) are properly handled.
  • Fixed removing keypoints in cinematics.
  • Fixed scrolling in web panels.
  • Show error message when image uploading has failed.
  • Issue fixed when using 1000+ excels in a single project.
  • Issue fixed where DEM does not properly update in 3D client visualisation.
Version 2019.8.0
Version 2019.8.0 was released on engine.tygron.com (LTS) on Friday May 31th 2019
Interface
  • The Tygron Geodesign Platform is a powerful tool to explore various scenarios. It gives users insight into the current situation, reviews and calculates future designs and involves stakeholders in the decision-making process throughout all the stages of the project. This functionality is reflected in the new interface with three tabs (Current Situation, Future Design and Multi Stakeholders).
Larger Maps
  • Again we expanded the area you can select on the Tygron Platform to 30 square kilometres. These bigger maps allow you to take on bigger cases and expand the possibilities for your clients. You can check if your hardware will be able to run the biggest size maps by selecting the hardware test under Options at the main menu.
Water
  • The newly developed Water Module gives clear insight in all water related subjects in your area. Too much (floods), too little (drought) and the quality of the water is all implemented and thoroughly tested. Run highly detailed simulations of floods and take into account things like breach growth, flow velocity and water depth.
Networks
  • Combine our new Water Module with the extensive Network Module that is now also available on the Tygron Platform. For instance see the effect of a flood on an electricity network in your area.
Project
  • By linking to more and more data sources we keep working on creating a truly realistic 3D representation of your area. You can now see dramatic improvements in projects outside the Netherlands based on Open Streetmaps.
Tygron Index
  • It’s also possible to share your own developed indicators and panels on our online store, the Tygron Index. You can download calculation models that are developed by other users and use them in you own projects. You can also share any indicators that you created yourself.
Version 2019.9.0
Version 2019.9.0 is released on preview.tygron.com (Preview) on Friday July 19th 2019
Overlays
  • New BETA Heat Stress Overlay based on RIVM Model.
  • New Heat Overlay includes: shadow map, sky-view map and wind map.
Other
  • New tree functions (e.g. Larch, Oak, Willow, Birch).
  • Option to set the project local timezone.
Version 2019.9.1
Version 2019.9.1 is released on preview.tygron.com (Preview) on Friday August 9th 2019
Overlays
  • Due to limited GPU Capacity on the Preview Server the max amount of grid cells has been reduced to 100.000.000.
  • Trees are now included by default in the Heat Overlay.
