Traffic Model
Traffic model in the Tygron Platform
The purpose of the default traffic model in the Tygron Platform is to calculate the effects of traffic on the 3D World through traffic intensity. In order to calculate this impact, data such as the number of lanes, traffic speed and the traffic intensity on a particular road can be added to the project. The traffic model is a static model that does not change by carrying out Actions, Upgrades or Measures for example. Read below how to create your own dynamic traffic model and use it in the Tygron Platform. The following (dynamic) overlays show data from/effects of the traffic model:
Traffic data
Height offset
This field specifies the height offset of a bridge.
Units per hour
This field specifies the traffic intensity: the number of units that drive on the road in an hour. For the data source, see traffic intensity.
Lanes
This field specifies the number of lanes that a road can have.
Noise Sigma
This field specifies the correction factor at reference traffic speed [1].
This value is used in the calculation of the Traffic Noise (Overlay).
Noise Tau
This field specifies the correction factor per 10 km/hour deviation from reference traffic speed [2].
Speedlimit
This field specifies the max allowed speedlimit on road or part of a road.
Data sources
When creating a new project a traffic model is generated for the selected project area, based on available open data sources. The following datasets are used:
Traffic intensity
The traffic intensity is depicted in the Platform by the Units per hour attribute (in the software named TRAFFIC_FLOW).
When generating a new project, the traffic intensity is assigned based on data sources. When the Units per hour attribute text color is black, the intensity is a default value based on the function. When the Units per hour attribute text color is red, the data is from one of the data sources below.
When the road is a highway, the data is probably from INWEVA 2015.
Otherwise, the intensity is based on the VI-Lucht & Geluid model. (see also: https://www.infomil.nl/onderwerpen/lucht-water/luchtkwaliteit/slag/hulpmiddelen/inschatten/)
This excel based traffic model estimates traffic intensity based on the following road characteristics:
- Traffic speed
- Is it a one way street or not?
- Is the road inside an urban area or not (NL: binnen of buiten de bebouwde kom)?
- Is there a separate cycle path along the road?
- Are there more than 2x2 lanes?
- Is parking along the road possible?
These characteristics combined with the urbanization factor, determines the type of road. In the Excel model, the different road types have different average traffic intensities. The average daytime traffic intensity is converted to an hourly value to be used for the TRAFFIC_FLOW attribute.
Add a custom Traffic Model
