Main Menu
This article is a stub.
After reading this page:
- you've learned about the Main Menu in the Tygron Engine web application
- you've learned about the different elements of the Tygron Engine main menu
- you've learned about the different sub menus available on the Tygron Engine main menu
Main menu
- In software development, the main menu is the main screen offering the top level of basic choices for software or a system.
http://dictionary.reference.com/browse/main+menu
Main menu of the Tygron Engine web application
- In the Tygron Engine web application, the main menu is the first screen after the log in panel and End Users License Agreement (EULA). On this main menu the top level of basic choices can be made by the user in the Tygron Engine web application, depending on the user's level of access rights.
Elements of the Tygron Engine main menu
- The main menu of the Tygron Engine web application consists of multiple basic elements for each user, independent of the user access level.
Left menu bar
- The left menu bar is the vertical area on the left side of the screen. The left menu bar contains all options that are available for the user's access level. The higher the access level, the more options will be displayed here.
Headlines panel
- On the lower half of the screen, near the middle, is a large white field, called the Headlines panel. On this panel major news updates are shared with the users. These can refer to anything Tygron related.
Updates panel
- Located on the lower half of the screen, on the right, is the Updates panel. On this panel small notifications are posted, usually of a more technical nature, such as when the server was rebooted for the last time.
Version and server information
- Near the bottom of the screen, under the Headlines panel, a string of text informs the user which build is currently in use on which server. This can be useful when a new build is anticipated, or when an issue (bug) needs to be reported.
Session invite message
- Not an integral part of the main menu, but important and available on all access levels in the main menu; the session invite message. This message is displayed whenever a client is invited to join a game session by the host/ game facilitator. Accepting this invite will automatically assign the client to a team, and the game will load.
