Warnings (Water Overlay)
Redirect page
Calculation warnings
When the Water Overlay is selected in the Editor, a number of warnings may appear in the right panel when a calculation is performed.
Calculation was cancelled
The calculation did not run to completion, because it was cancelled by the user. Depending on the calculation being performed, partial results may be available.
Calc too long forced timeout
The calculation exceeded the allowed calculation time. During business hours (9-17, GMT+1, during weekdays), there is a maximum calculation time of 1 hour. If during business hours a calculation has been calculating for an hour, the calculation times out automatically. Depending on the calculation being performed, partial results may be available.
Error in GPU calculation
During the calculation, an unknown error has occurred. This may be due to an unexpected configuration of the specific calculation, or an internal error in the calculation infrastructure. Please contact support with a description of the calculation and its related settings to further investigate the issue.
Insufficient memory
An overlay's simulation model comprises numerous data arrays, such as fluxes and water levels in a water simulation, which are processed on the GPUs. When this error arises, it indicates that the total number of data arrays required for the simulation exceeds the available GPU memory (note that GPUs have their own dedicated memory, distinct from the general RAM used by the CPU). This error is constrained by hardware limitations and can only be addressed by reducing the dataset size. There are several solutions:
  • The first approach is to increase the grid cell size, as fewer cells will result in reduced memory usage.
  • The second option involves simplifying the simulation by using fewer result types. For instance, result types like AVG_DIRECTION, FLOOD_RISE_RATE, or TRACERS in the water model generate additional arrays.
  • Disabling model options like groundwater in a Water simulation can also help decrease the data volume.
  • Lastly, the number of timeframes does not affect memory usage. Timeframes are snapshots taken during the simulation and sent back to the Project on the CPU, but they do not require additional data arrays on the GPU.
Prequel
When a Grid Overlay encounters an error, its results may not be valid. Any other Grid Overlay which uses that first Grid Overlay as a prequel will warn about that error in one of the prequels taking place. Subsequent Grid Overlays relying on that one will also report the error.
Limited cycles. Inaccurate results
It took too many calculation cycles to perform the calculation. The maximum amount of calculation cycles is 2147483647. The amount of cycles is dictated by the complexity, size, and duration of the simulation. More water with a higher maximum impulse across a larger calculation area over a longer period of time requires more computational cycles to accurately compute.
Invalid constructions
One or more constructions used in the calculation are invalid. They may be incorrectly configured, or interfered with by the presence of other constructions. More information for the individual constructions with errors can be found in the Water Overlay Wizard, or under the Construction warnings header.
Large cell size. Inacurate results
The grid cell size has been configured as greater than 4 meters. This means water may have difficulty flowing into alleys or through fair-sized waterways, and other accuracy-related artifacts may present themselves in the calculation results.
Heightmap resolution is too low
The resolution of the heightmap is lower than the grid cell resolution, meaning that even though more accurate results might be expected, it's not possible to refine the detail of water flow to the configured accuracy. The only way to enhance the height map accuracy is to load in a new Project with a more detailed DEM resolution.
Feature warnings
Water Area
Water Area: The water level much higher than the average land height
The water level is much higher than the average land height, which likely means an improper value has been imported as Water Level. The effect in the model is that water will be initialized in waterways as a high block exceeding the average surface height, so the simulation will start with a sudden flood emenating from the waterways. Check your data for placeholder values.
Water Area: The water level is much lower than the average land height
The water level is much lower than the average land height, which likely means an improper value has been imported as Water Level. The effect in the model is that waterways will be initialized with excessively low water levels, if they are even deep enough to contain any water. Check your data for placeholder values.
Inundation Area
Inundation Area: The inundation level is much higher than the average land height
The water level is much higher than the average land height, which likely means an improper value has been imported as Inundation Level. The effect in the model is that water will be initialized on the surface many meters high, which is an unrealistic starting situation. Check your data for placeholder values.
Inundation Area: The inundation level is much lower than the average land height
The water level is much lower than the average land height, which likely means an improper value has been imported as Inundation Level. The effect in the model is that no water will actually be placed on the surface, except in points where the terrain dips far below the average height (without being a waterway). Check your data for placeholder values.
Sewer Area
Sewer: Sewer Storage is negative, which is not allowed
The Sewer Area is configured to have a negative amount of sewer storage. All sewer storage must be strictly positive and non-zero. Check your sewer data and adjust the Sewer Storage values where possible.
Aquifer
Aquifer: Aquifer does not have a positive non-zero KD value.
The Sewer Area is configured to have a negative hydraulic conductivity, which directly dictates maximum flow speed. The hydraulic conductivity must be positive and no-zero, otherwise the underground flow speed would be similarly negative or zero. Check your aquifer data and adjust the aquifer kd where possible.
Breach
Breach: Breach shares its Input Area with another Breach
The Breach is properly connected to an input area, but another Breach is connected to the same input area. Make sure every breach using an input area has its own input area.
Breach: Breach uses an empty Input Area, which will have no effect
The Breach is properly connected to an input area, but the input area is not a polygon in the 3D world.
Breach: Breach has an invalid Input Area
The Breach refers to an Area as Input Area, but the referred Area is not configured to be an Input Area.
Breach: Breach uses an External Area as input, but it is not allowed to be empty
