Template:Nav-group
Revision as of 12:31, 26 August 2020 by Rudolf@tygron.nl (talk | contribs)
Example:
To be used in a Template:nav.
Parameters:
  • 1: Name of the group
  • 2..n: Entry in the group. Automatically linkified.
  • 2link..nlink: Replacement for a specific entry in a group, to facilitate defined links. Preferably not used, but can facilitate external links for example. Don't forget to skip the associated number.
  • postappend: What to append every name with. (e.g. "Heat Stress" as text, "Heat Stress Overlay" as link, postappend should be " Overlay")
  • group: Title or link, if this is a main group indicator. Should not be used along with 2...n.
Additional parameters can be generated with:
var itterations=25;
var base='--></noinclude>{{#if:{{{%s|}}}{{{%slink|}}}| • |}}{{#if:{{{%slink|}}}| {{{%slink|}}} |{{linkappend|post={{{postappend|}}}|postd={{{postdepend|}}}| 1={{{%s|}}} }}}}<noinclude><!--';
var output = '                               --></noinclude>{{#if:{{{%slink|}}}| {{{%slink|}}} |{{linkappend|post={{{postappend|}}}|postd={{{postdepend|}}}| 1={{{%s|}}} }}}}<noinclude><!--'.split('%s').join(2);
for (var i=3; i<=itterations ; i++ ) {
    output = output + '\r\n'+base.split('%s').join(i);
console.log(output);
