How to import a time sequence with a CSV
How to import a time sequence with a CSV:
- In the Water Overlay Wizard, go to step 2 and find the Construction you would like to enter a time sequence for.
- Click on the Dynamic button for the desired attribute adn then click on Select.
- In the new panel that pops up, click on Import new CSV and select the CSV file.
- Optionally, change the delimiter and time units and click on Ok. The data in the CSV is now used to set the attribute dynamically.
- The CSV file to import a time sequence should look as follows:
time;weir 3600,0.03 7200,0 9000,0.03 10800,0.06
The first row should contain the headers. The name of the headers above are an example and may vary.
