Height offset (Function Value)
Function value | Attribute | Unit | Per category | Range | Description |
Height offset | HEIGHT_OFFSET_M | m | How many meters above or below the calculated ground this construction should be visualized. This is intended for bridges or other constructions on water, so that they can be lined up appropriately with the surrounding land, or float at an appropriate height. |
Values
- The default values for this Function Value are conductive for a generic graphical styling
- Buildings generated during project creation can have their values overwritten based on the height of surrounding terrain, so that bridges connect to the appropriate parts of the terrain.
- The Water Overlay includes the height offset of constructions when computing the elevation model. For example, bridges with a height offset will be considered as high as their height offset.
