How to add rain barrels to your project
Revision as of 14:42, 2 November 2020 by Reijn@tygron.com (talk | contribs)
A rainbarrel can be added to a project as an action to improve garden drainage capacities, besides that it also improves the awerness of residents towards neighborhood water management.
How to add a rain barrel to your project:
- Hoover over the buildings button and select Edit Function Values.
- Select the standard garden in the Function Values list (if the standard garden is not in the list yet, you need to add it by pressing the Add button next to Fucntion and selecting the standard garden.
- Press the standard garden and select duplicate.
- Adjust the name of Standard garden 2 into Garden with Rain barrel.
- Adjust the function values to the desired set.
Editor → Future Design (Ribbon tab) → Upgrade Types (Ribbon bar) → The Upgrade Type to edit (Left panel)
How to add a rain barrel as an upgrade.:
- Go to the Upgrade Tyges ribbon and a ADD a new Upgrade by pressing the Add button in the bottom left corner.
- A new Upgrade Type appears, modify the Upgrade Type in the right sided panel.
- Rename the Upgrade in Rain Barrel Garden Upgrade.
- Press Add Pair in the bottom panel.
- Change the funtion in the bottom panel by selecting standard garden as the Input Function and Garden with Rain Barrel as the Resulting Function.
- A new Upgrade has been created.
Editor → Future Design (Ribbon tab) → Actions (Ribbon bar) → The Action Menu to edit (Left panel) → Actions tab (Right panel)
How to add a rain barrel as an action.:
- Go to the actions ribbon and a Add a new acion by pressing the Add button in the bottom left corner.
- A new action menu appears, modify the action in the right sided panel.
- Rename the Action in Rain Barrel, change the image by selecting the category_waterbasket.png as image and select the desired stakeholders.
- A new action has been created.
- Select Actions in the ribbon on the right side panel and select Rain Barrel Garden Upgrade in the upgrades drop down menu.
- The values used for the Rain Barrel Garden are free to be selected by the user
