Model attributes (Subsidence Overlay)
Revision as of 10:31, 19 November 2020 by Reijn@tygron.com (talk | contribs)
The subsidence overlay also has attributes. All attributes have a default value, but can be changed to configure the subsidence calculation.
Attribute Description Default value Remark
A The A parameter in the Oxidation formula. 0,023537 This value is recalculated between 1-year time steps of the calculation.
B The B parameter in the Oxidation formula. 0,01263
C The C parameter in the Oxidation formula. 0,00668
CLIMATE_FINAL_TEMP The final temperature in the final year of the total simulation time. 10,7 This is the temperature at the end of the calculation. The last 1-year calculation step uses the temperature from the beginning of that year.
CLIMATE_OXIDATION The oxidation factor used to recalculate the climate values between 1-year calculation steps. 0,67
CLIMATE_SOIL_TEMP_FACTOR The soil temperature factor used to recalculate the climate values between 1-year calculation steps. 0,5
DEFAULT_CLAY_THICKNESS If no clay thickness value can be found in a particular grid cell, this value is used instead. 0,2
DEFAULT_PEAT_FRACTION If no peat fraction value can be found in a particular grid cell, this value is used instead. 0,4
DEFAULT_TOP_LAYER_THICKNESS If no top layer value can be found in a particular grid cell, this value is used instead. 5,0
HI_PASSIVE_DRAINAGE When passive drainage is applied, the GHG (highest ground water level) is increased by this amount. -0,10 Due to definitions "Increase" means that the distance between the surface and this ground water level increases. The default value causes the ground water level to come closer to the surface.
LOW_PASSIVE_DRAINAGE When passive drainage is applied, the GLG (lowest ground water level) is increased by this amount. 0 Due to definitions "Increase" means that the distance between the surface and this ground water level increases. The default value does not affect the ground water level.
YEARS The amount of years to simulate during the calculation, in 1-year steps. It's possible to set this value anywhere between 1 to 1000. 30 This attribute is linked to one of the keys of the overlay. When this attribute is changed the key is changed as well.
{{overlay attributes|suppresscategory=true|allowselflinks=true|
