Tracer ABCD (Water Overlay)
Template:Construction attributes
Constructions with a positive TRACER Attribute are known as chemical emitters. Constructions with a negatice TRACER Attribute are known as chemical decomposers.
Structures which are defined to create a negative amount of chemicals function as a scrubber or decomposer, removing the specified quantity of chemicals from the hydrological model.
In situations where water is absent, chemicals will not be moved between cells.
- Chemical emitters must be constructions on the surface, not underground constructions.
- Chemical emitters's attributes do not take the form of function values, and thus must be added manually or as part of loading in geodata.
- Chemicals have generic definitions, in terms of name and magnitude, to allow for the modeling of arbitrary tracers.
- Surface flow formula (Water Overlay)
- Underground flow formula (Water Overlay)
- Surface infiltration formula (Water Overlay)
- Underground infiltration formula (Water Overlay)
- Surface model (Water Overlay)
- Underground model (Water Overlay)
- Infiltration model (Water Overlay)
- Tracer flow model (Water Overlay)
Template:WaterOverlay hydrological construction attribute nav
