Drainage formula (Water Overlay)
Drainage passive: First the flow capacity is calculated
- is the ground water level in meters
- is the water level in the waterway
- is the drainage datum height in meters.
- is the drainage area size in square meters.
- is the average storage percentage of the ground above the drainage.
- is the amount transfered for a balanced ground and surface water level
- is the amount available in the ground above the drainage.
- is the drainage capacity at time t
- is the actual drainage at time t
