Drainage formula (Water Overlay)
Revision as of 15:05, 4 December 2020 by Frank@tygron.nl (talk | contribs)
Drainage passive: First the flow capacity is calculated
if w_w > w_g then:
else:
is the ground water level in meters
is the water level in the waterway
is the drainage datum height in meters.
is the drainage area size in square meters.
is the average storage percentage of the ground above the drainage.
is the amount transfered for a balanced ground and surface water level
is the amount available in the ground above the drainage.
is the drainage capacity at time t
is the actual drainage at time t
