Waterway level change benchmark (Water Module)
Revision as of 09:18, 11 December 2020 by Frank@tygron.nl (talk | contribs)
Initially, the ground water table is the same as the water level in the waterway. Suddenly the level in the waterway rises with h0 meters. This causes water to infiltrate into the ground, raising the ground water table.
When the water level in the water way changes, the water table level will also change over time. The relation between water level in the waterway and the ground water table at distance x from the water way is described by the following formulas: Water level raised: h(x)h0=erfc(xS4kDt)
Water level lowered: h(x)h0=erf(xS4kDt)
The formula erf is the complementary error function. Failed to parse (syntax error): {\displaystyle erf(z) = \frac{2}{\sqrt(\pi}}\int\limits_{0}^{z}e^(-t^2)dt} erfc(z)=1erf(z)
h(x): change in freatic groundwater table (m)
h0: change in water level in the waterway(m)
x: distance to the water way (m)
t: time since the water level change
kD: transmissivity of the aquifer (m2 / day)
S: freatic water storage fraction.
