How to edit a Combo Overlay formula
How to add the Combo Overlay:
- Select the Combo Overlay by hovering over custom in the Overlay dropdown menu
- In the left panel, select the newly added Combo Overlay.
- In the right panel, select from the drop down menus, the desired Grid Overlays as input the Combo overlay can be selected
How to edit the Formula of the Combo Overlay:
- Select the (enlarge) button in the right panel
- The Edit Fomula window pop-up screen will appear
- Notice that in the bottom of the window are several operator buttons. When selecting these buttons they will be automatically added to create the formula. Make sure to change the variables to the variables you would like to use. Use A,B and C to refer to the selected Overlays in the right panel.
- If needed, you can also type extra commands like , and ()
- When pressing close the Tygron Platform will automatically check the correctness of the formula
- The formula is now used to calculate and visualize the result in the Combo Overlay
The menu of the Combo Overlay in the right side panel.
The enlarged formula window of the Combo Overlay.
