How to export an Object output attribute as measurement
How to export an Object output attribute as measurement:
- Click on a Water Overlay
- Open the Measuring tool
- Select the Hydraulic structure of which you want to export the OBJECT_FLOW_OUTPUT attribute and note that you will see the values in a graph in the Measuring tool.
- Click on the plus icon to save this Measurement
- Then go to the Current situation tab --> hover over TQL queries and select Export Geo Data
- Select the corresponding Water Overlay and the Comma Seperated Value for the export format
- Click on Export File. Now the CSV file is downloaded
Step 3. Select the Hydraulic structure
Step 5. Click on Export Geo Data
Step 6. Select the Water overlay and the CSV format. Click then on Export File.
