Account management
This article is a stub.
After reading this page:
  • you've learned about user account management
  • you've learned about the different account types in the Tygron Engine
  • you've learned how accounts relate to their domain
  • you've learned about the different license types
  • you've learned how to change user account details
User Account management
User management is the process that focuses on the administration of users of IT and information systems. This process manages the registration of users and the authorisation of their roles within a system. Authorised access is secured with a user specific login name and password.
User Management can control, for example:
  • The projects a user can access
  • Whether access to that project is read-only
  • If a user can update his credentials (login, password)
  • If a user can update relevant project data
  • If a user can host or join a session with other users
Different account types in the Tygron Web Application
The Tygron Web Application uses account management to enable user access to their proper projects, and with the required rights to perform the actions desired. To ensure that users have access to their assigned projects, and their assigned projects only, users are grouped in so called user domain groups (="domain"). Within a domain, users can have different roles, or account types, assigned. These types or roles determine the actions a user can perform within his domain. These different account types are described below:
Invite Only
The Invite Only account type is the account type with the lowest access level. When using this type, the user can only be invited to a session. Within the domain at least one Multiplayer account type must be available, to be able to host sessions where Invite Only accounts can be joined to. The user can only perform a minimum of actions, such as:
  • Run the hardware benchmark test
  • Call up online support resources, such as the Wiki and Forum
  • Read the Legal Notices
  • Log out of the Tygron Web Application
Single Player
With this account type it is allowed to start available games in Single Player or Demo mode besides the options available for the Join Only account type. Thois account is used when there are both single player and multiplayer games available in the domain, however, it is desired to restrict access to only the single player project(s) for one or more users within the domain.
With this account type users can:
  • Change user account details (name, family name & password)
  • Start a game session in Single Player or Demo mode
Multiplayer
The Multiplayer account is used for hosting and joining game sessions for multiple players. With this account type a user can select, besides the same options as the Single Player account, to host a new or previously saved multiplayer game session, or to join an already active multiplayer game session. This is the most common account for the general purpose of playing multiplayer games.
  • Host a new or already saved multiplayer game session
  • Join an already active multiplayer game session (hosted by someone else)
Editor
This account type has the same options available as the Multiplayer account type. This account type can also create new games, edit existing games, or join others within the same domain, in an editing session.
  • Create a new or edit an already saved game project
  • Join an already active editor session with another user within the same domain
Domain Admin
The Domain Admin account has the highest access level available to end users of the Tygron Engine. This account has all the perks of the Multiplayer account plus the options to manage all the users in the domain, manage the available projects within the domain, manage the active sessions within the domain and the license for the domain. If no domain admin account is available within a domain, this role is being taken care of by Tygron Customer Support.
  • Create or change users within the domain
  • Manage the projects within a domain
  • Manage active sessions within a domain
  • Change the license of the domain
Account Type Description Available options
in main menu
INVITE_ONLY This account can only be invited to a multi player session Invite only
SINGLEPLAYER This account can only access Demo and Single Player games Singleplayer
MULTIPLAYER This account can start and join multiplayer sessions, including the inviting of INVITE_ONLY accounts Multiplayer
EDITOR This account type can, besides hosting and playing multiplayer games, create and edit its own games Editor
DOMAIN_ADMIN This account is the highest access level available to users. With this account you can also manage other accounts from your user domain. Group Admin
Domain
User accounts are grouped under a domain
User Domain Groups
User accounts are grouped under a "domain" (=user group). This is a convenient manner to ensure that users from a certain group can only access the games assigned to their domain. This to avoid competitors to be able to sea each others games for example, or to avoid caustic behaviour such as editing or deleting games from other user domains.
Please note that the licensing is also linked to the domain; a domain receives a license, not the users individually!
Domain license types
A domain is licensed for using the Tygron Engine. This means that there is a limit on projects per domain, not a limit on the amount of users or projects per user. Licenses divided over different classes and types of licensing. A domain receives, for starters, an Educational or Non-Educational class license. The Educational class is dedicated to educational users, such as educational institutions and students. Within this licensing group also a free trial license can be requested. Non-Educational class licenses are for commercial parties, without educational purposes.
For both classes different types of licenses are available:
Use only, no editing
This license is commonly used for playing already existing games, such as the Climategame or the Krimpgame. The user has only access to the already available games in their domain, which are usually created in another domain and then shared with this "Use Only" domain. No new games can be created or edited, so there is no use for an editor account within this license.
1 Project
With this license only one project can be created and edited on the Tygron Server. Support is also only available for this project.
5 Projects
With this license five projects can be created and edited on the Tygron Server. Support is available for all five projects.
10 Projects
With this license ten projects can be created and edited on the Tygron Server. Support is available for all ten projects.
Unlimited
With this license an unlimited amount of projects can be created and edited on the Tygron Server. Support is available for all projects.
Changing user account and user domain details
>>>See Discussion
