Version 2022.4.0
Version 2022.4.0 is released on preview.tygron.com on December 6th 2021.
Geo Share
- Accessible from main menu, no session needed anymore.
- Support directories and accessible from GeoWizard.
- Drag and drop directories into Geo Share window.
- Support for more file types (e.g, txt, pdf).
- Integrated Geo Share into firewall.
- NOTE: Update BREAKS old viewers, re-add to fix.
Overlays
- GeoTiff input has been replaced by Grid input.
- Water Overlay supports multiple grid inputs (e.g. water level, elevation).
- Grid Overlays can be resized to 25cm and max 5 billion cells.
- Watershed Overlays now ignore no-direction values.
- Geotiff Overlay can now reference multiple geotiffs, where each geotiff is a separate timeframe of the Geotiff Overlay.
Geo
- GeoPlugins can now be (de)activated in the advanced options panel when selecting a new project area.
- GeoPlugins can now also reference GEOJSON files from the Geoshare.
- GeoPlugins can now handle WFS sources that only support GML data.
- The Geo-Wizard now supports a Geometry-filter as an alternative to the Name and Value filter.
- The Geo-Wizard now supports generating an automatic matching based on existing Function Names. This also applies to Stakeholders, Net Types and Terrain Types.
- Fixed a loss of precision issue of coordinates originating from imported GML data that was defined in latitude and longitude degrees.
TQL
- New XC-Query option that selects all items in e.g. a neighborhood.
- Api calls to query endpoint can now contain multiple TQL statement.
- Editing existing global queries in the Query tool controller is now also possible.
Other
- Improved CRS support, with option to force XY (Longitude, Latitude).
- API references related events and better examples.
- Update to underlying GPU architecture.
- The Waterbalance panel of Water Overlays are no longer disabled on test runs.
- The 2D map viewer organizes its overlays now better and will play timeframes automatically when selected.
- Several smaller bug fixes.
