High ground water prequel (Subsidence Overlay)
Revision as of 08:21, 11 February 2022 by Rudolf@tygron.nl (talk | contribs)
Name | Prequel | Underlying data | Unit | Range | No data | Description |
High ground water | HIGH_GROUND_WATER_LEVEL | Subsidence Prequel | m | The depth of the ground water level, relative to the surface |
The initial high groundwater level in the Subsidence Module at the start of the simulation can be initialized using a prequel Grid Overlay.
In the Subsidence Overlay Wizard it is possible to select one of the Default datasets provided, to import and create a GeoTIFF Overlay or to do nothing and proceed with the next step.
Default data
For the Netherlands, a number of groundwater GeoTIFFs are provided by default, based on data provided by The Netherlands Hydrological Instrumentarium:
- NL_GHG_kk-nhi (Average highest watertable)
- NL_GLG_kk-nhi (Average lowest watertable)
- NL_GVG_kk-nhi (Average spring watertable)
These GeoTIFFs can be linked to the Subsidence Overlay using a GeoTIFF Overlay and referencing it with this prequel.
- Specified as m below terrain height
- When no prequel is specified, the water levels of groundwater level areas are used to initialize groundwater levels.
