Template:About
Revision as of 15:19, 15 February 2022 by Rudolf@tygron.nl (talk | contribs)
Source: https://en.wikipedia.org/w/index.php?title=Template:About&oldid=718032354
Parameters:
  • 1: What this article is about
  • Following parameters
    • Parameters in a pair (2+3, 4+5, 6+7) : Adds "For 1st of pair, see 2nd of pair."
    • Single parameter: Adds "For parameter, see pagename (disambiguation)"
Examples:
For other uses, see About (disambiguation).
This page is about the Area attribute. For the model attribute, see Limit area model attribute (Water Overlay).
This page is about the Area attribute. For the model attribute, see Limit area model attribute (Water Overlay). For other uses), see About (disambiguation).
This page is about the Area attribute. For the model attribute, see Limit area model attribute (Water Overlay). For Limitation Areas, see Limitation area (Water Overlay).
This page is about the Area attribute. For the model attribute, see Limit area model attribute (Water Overlay). For Limitation Areas, see Limitation area (Water Overlay). For other uses, see About (disambiguation).
