Model attributes (Traffic NO2 Overlay)
Revision as of 14:11, 25 February 2022 by Frank@tygron.nl (talk | contribs)
The Traffic NO2 Overlay can be configured with a number of Attributes.
Icon | Attribute | Unit | Range | Description | Default value |
BUSES_ACTIVE | boolean | Whether buses are to be included in the model's calculations. | True | ||
CARS_ACTIVE | boolean | Whether cars are to be included in the model's calculations. | True | ||
TRUCKS_ACTIVE | boolean | Whether trucks are to be included in the model's calculations. | True | ||
VANS_ACTIVE | boolean | Whether vans are to be included in the model's calculations. | True | ||
HOURS | h | An array of the hours of day that need to be calculated. Each hour will result in a timeframe. | 8 | ||
BASE_NO2 | μg/m3 | The background concentration of NO2 in the air. | 0 | ||
BASE_O3 | μg/m3 | The background concentration of O3 (ozone) in the air. | 42 | ||
MIN_TREE_HEIGHT_M | m | The minimal height for a tree before it is counted for the trees factor. | 2 | ||
EMISSION_NO2_CAR | μg/m3 | The NO2 emission of a car. | 0.09 | ||
EMISSION_NO2_BUS | μg/m3 | The NO2 emission of a bus. | 0.61 | ||
EMISSION_NO2_VAN | μg/m3 | The NO2 emission of a van. | 0.41 | ||
EMISSION_NO2_TRUCK | μg/m3 | The NO2 emission of a truck. | 0.46 | ||
EMISSION_NOX_CAR | μg/m3 | The NOx emission of a car. | 0.36 | ||
EMISSION_NOX_BUS | μg/m3 | The NOx emission of a bus. | 5.88 | ||
EMISSION_NOX_VAN | μg/m3 | The NOx emission of a van. | 6.9 | ||
EMISSION_NOX_TRUCK | μg/m3 | The NOx emission of a truck. | 8.99 | ||
EMISSION_JAM_NO2_CAR | μg/m3 | The NO2 emission of a car in a traffic jam. | 0.14 | ||
EMISSION_JAM_NO2_BUS | μg/m3 | The NO2 emission of a bus in a traffic jam. | 0.98 | ||
EMISSION_JAM_NO2_VAN | μg/m3 | The NO2 emission of a van in a traffic jam. | 0.68 | ||
EMISSION_JAM_NO2_TRUCK | μg/m3 | The NO2 emission of a truck in a traffic jam. | 0.76 | ||
EMISSION_JAM_NOX_CAR | μg/m3 | The NOx emission of a car in a traffic jam. | 0.57 | ||
EMISSION_JAM_NOX_BUS | μg/m3 | The NOx emission of a bus in a traffic jam. | 9.4 | ||
EMISSION_JAM_NOX_VAN | μg/m3 | The NOx emission of a van in a traffic jam. | 11.32 | ||
EMISSION_JAM_NOX_TRUCK | μg/m3 | The NOx emission of a truck in a traffic jam. | 14.74 | ||
ROAD1_30M_A | The "a" factor used to calculate the dilution effect of roads up to 30m from the road's center. | 0.000325 | |||
ROAD1_30M_B | The "b" factor used to calculate the dilution effect of roads up to 30m from the road's center. | -0.0205 | |||
ROAD1_30M_C | The "c" factor used to calculate the dilution effect of roads up to 30m from the road's center. | 0.39 | |||
ROAD1_60M_ALPHA | The alpha factor used to calculate the dilution effect on roads up to 60m from the center of the road. | 0.856 | |||
ROAD1_60M_POWER | The power the alpha factor is raised to when calculating the dilution effect on roads up to 60m from the center of the road. | -0.747 |
