Traffic noise formula (Traffic Noise Overlay)
The calculations for the Traffic Noise Overlay follow the standard rekenmethode 1 (SRM 1), as described on http://wetten.overheid.nl/BWBR0031722/2015-07-01#BijlageIII:
LAeq = E + Co + Cr - Da - Dl - Db - Dm
  • LAeq: equivalent noise level (dB(A))
  • E: emission
  • Co: acceleration term (default = XXX dB(A))
  • Cr: reflection term (omitted)
  • Da: distance reduction
  • Dl: air reduction (default = XXX dB(A))
  • Db: surface reduction (default = XXX dB(A))
  • Dm: meteorological reduction (default = XXX dB(A))
Default values are taken from InfoMil [1]
Emission
Emission is computed as:
E=10log10(10Ec10+10Ev10+10Et10+10Eb10)
The emission per type of traffic is computed similarly, with values specific to the type of traffic. It is calculated as followed for cars:
Ec=Ec,start+Ec,multlog10(VcV0c)+10log10(QcVc)+σ+τlog10(VcV0c)
E = the combined noise emission
Ec = the calculated noise emission for cars
Ev = the calculated noise emission for vans
Et = the calculated noise emission for trucks
Eb = the calculated noise emission for buses
Ec,start Emission start value. Configurable with model attribute Emission start (Traffic Noise Overlay). See also: [2]
Ecmult Emission factor. Configurable with model attribute Emission mult (Traffic Noise Overlay). See also: InfoMil [3]
σ = road surface correction value at reference traffic speed. Configurable in roads with Function Value TRAFFIC_NOISE_SIGMA
τ = road surface correction factor per 10 km/hour deviation from reference traffic speed. Configurable in roads with Function Value TRAFFIC_NOISE_TAU
Distance reduction
Distance reduction is computed as:
Da = 10 * log(r)
  • r: shortest distance between the source and point of evaluation
  • If the traffic amount is defined as a single value, that value is used for all defined hours. However, if the amount if an array of values, each of the 24 indexes of that array are assumed to correspond to the hour denoted by those indexes, and as such that specific value from the array is used.
