How to adjust the starting budget of a Stakeholder
The Budget a stakeholder has during a session can be adjusted for each stakeholder via the Stakeholder ribbon. When selecting a stakeholder, the start budget is visible in the right panel of the Tygron Platform. By default, the start budget of a stakeholder is '0', although this can be adjusted to a desired amount.
How to adjust the starting budget:
- Click on Stakeholders.
- Click on the desired Stakeholder in the left panel.
- Adjust the Start Budget on the right side of the Tygron Platform to the desired amount.
How to adjust the aditional budget:
- Select the level that needs to be adjusted, this can be done for every level.
- Adjust the Additional Budget on the right side of the Tygron Platform to the desired amount.
