Camera
The main camera modes available to navigate in the 3D Visualization are:
Standard camera
Top down camera
Free camera
The secondary camera modes, less common but still useful, are
Walk camera
Walk camera (below surface)
Cinematic camera
Cinematic edit camera
Standard
This is the default camera mode. It provides different views based on the zoom level this camera is in. Close to the ground the camera is angled to provide a perspective in the 3D Visualization. When zooming out the camera will slowly settle into a cardinally-locked top-down perspective.
- Left mouse button (hold)
- Drag the camera along a flat plane, depending on the location the left mouse button was pressed.
- Right mouse button (hold) or middle mouse button (hold)
- Move the mouse left and right to rotate the camera around the upward axis defined by point the camera is currently looking at.
Move the mouse up and down to change the perspective angle. The perspective angle can be limited, depending on the zoom level of the camera.
- Scroll wheel up-down
- Zoom in and out one zoom level respectively.
- Arrow keys
- Move the camera in the direction of the arrow key used.
- Space
- Switch directly between a high and low perspective.
Top-down
This mode allows for an unskewed overview of spatial features at any zoom level.
- Left mouse button
- Drag the world side to side along a flat plane.
- Rotate the camera directly above point the camera is currently looking at, along the vertical axis extending from that point. But only when low enough.
- Smoothly zoom in and out respectively.
- Arrow keys
- Space
Free
This mode allows for unlimited zooms and rotation.
- Left mouse button
- Rotate the camera around the point the camera is currently looking at, along a spherical surface centered around that point.
- Zoom in and out respectively in discrete steps.
- Arrow keys
Secondary view modes
Walk mode
- W-key and S-key
- move forwards and backwards.
- A-key and D-key
- turn left and right.
- Space-key
- switch between above and below DTM
