Log in
Please note: This page is currently being updated! |
After reading this page
- you've learned about the Tygron Engine log-in panel
- you've learned how to log-in to the Tygron Engine with a Tygron account
- you've learned how to log in with an email Invite Code
- you've learned how you can select to automatically log in each time you start the application
- you've learned how you can reset your lost password
Login Panel of the Tygron Engine web application
Go to https://www.tygronengine.com. The login screen appears.
login screen
How to log in to the Tygron Engine
In the Tygron Engine web application you need to login. After logging in you get access to the Tygron Engine and start editing your game. You need a user name and a password before you can login. You can sign up for an account on our website. You can also request a free trial account
Automatically logging in
If you need to login often on the same system, you can select to save your password. You should be aware, that if you select this option, anyone who accesses the Tygron Engine application on your computer, has access to your account and project(s) without having to enter your log-in credentials. Also please note that this setting will expire after one week.
Automatic login check box
Logging in with an email Invite Code
It is now possible to invite someone to join a session, even when this person has no Tygron account. This person will receive an email with an access code. By selecting the option 'Click here to log in with an email Invite Code', the invited user will be given the option to log in with the received access code.
Use the Invite Code option
Enter the received Invite Code here
Lost Password
In case you lost your password, you can recover it by selecting the "Lost Password, click here to recover" link. When you enter your username, a new password will then be sent to your e-mail.
Log on to the Tygron Engine
Go to www.tygronengine.com
Login with your Username and Password
- Goto http://www.tygronengine.com and login at with your username and password
- You will proceed to the main screen
1. login screen
2. Main screen
