Install
An installer is a software component used for the installation, maintenance, and removal of the Tygron Client software.
What is the function of the installer in relation to the Tygron Client?
The Tygron Client is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
Before you can install the Tygron Client (LTS) you first need to download the installer.
How to Download the installer for the Tygron Client (LTS):
  1. Open your browser
  2. open https://engine.tygron.com/
  3. Select "Windows (64 bit) Installer"
  4. "TygronEngineWin64.msi" will start downloading
  5. Once the download has been completed proceed to the next step, "Running the installer"
Before you can install the Tygron Client (Preview) you first need to download the installer.
How to Download the installer for the Tygron Client (Preview):
  2. open https://preview.tygron.com/
Before you can use the Tygron Client you first need to run the installer.
How to Install the Tygron Client:
  1. Open "TygronEngineWin64.msi"
  2. the installer will install the Tygron Client Application
  3. A desktop shortcut and a start-menu shortcut will be created
Launching the Tygron Client
Once the installer has completed you can launch the Tygron Client. See the following page to learn how to log in.
How to Start the Tygron Client:
  1. Launch "Tygron Platform" from the desktop shortcut or the start menu
  2. You will be prompted with the login screen.
