Hi ground water level (Subsidence Overlay)
Icon | Key | Unit | Range | Description | Default value |
HI_GROUND_WATER_LEVEL | m + datum | The yearly high (average) ground water level in this area. Note that this is the ground water level (datum), not the ground water depth. | n/a |
- This value is overruled when a High ground water prequel is loaded in. Regardless of whether a GeoJSON or GeoTIFF is used, this should be a non-negative value. Negative values would represent water on the surface of the land, and may lead to unpredictable behavior.
