Requirements
Below are the computer hardware requirements needed to run the Tygron Client, which is an application that allows you to connect with the Tygron Platform.
Hardware
Your hardware is automatically categorized into the following scores. The total score of your computer is based on the lowest scoring component, and will affect both the default graphical settings.
Graphics Setting CPU (Processor) Memory (RAM) GPU (Videocard)* Notes on score
LOW Celeron At least 4GB RAM Benchmark score below 1000
with OpenGL 4.0
Computers with this score are not fully supported. Graphical issues and slow responses can be expected.
MEDIUM AMD Athlon
Intel Core 2
Intel Pentium
At least 8GB RAM Benchmark score above 1000
HIGH Intel i3, i5, AMD Ryzen 5 At least 16GB RAM Benchmark score above 4000
EXTREME Intel i7, AMD Ryzen 7, 9 At least 32GB RAM Benchmark score above 10.000
* We have found that NVIDIA cards provide the best stability in comparison to Intel and AMD. Therefore, we can strongly advise NVIDIA Geforce RTX 3050 (or better) for desktop and laptops computers. We recommend looking for cards in the high-end consumer segment (GeForce), as the Tygron Client does not make use of the extreme-precision capabilities of the more expensive Quadro cards.
Screen resolution 1280 x 800 pixels or higher
Operating system ** Windows 10, 11 (64 bit)
Internet connection *** Required
** Only Windows (10/11) is currently officially supported. Although it's possible to download an experimental version for linux, usage of the Tygron Client on this operating system is not officially supported, and at the user's own risk. An experimental Mac OSX version is at the moment not available.
*** There are no specific requirements to the internet connection. However, faster connections are better, especially when working with large data sets. We also strongly advise to test the performance and connectivity of the available connection when preparing for a session or presentation using the Tygron Client.
Project Area
The amount of memory (RAM) determines the maximum Project area size that the Tygron Client can handle on a speciffic system. Note: you can also create bigger Projects directly via the API, these just can't be visualized by the Tygron Client on a system with a smaller then required amount of RAM. The exact maximum map size also depends on the graphics setting, the table below gives an approximation.
Project Area* Memory (RAM) Notes on score
10x10 KM At least 4GB Computers with this score are not fully supported. Graphical issues and slow responses can be expected.
20x20 KM At least 16GB
30x30 KM At least 32GB
60x60 KM At least 64GB Davinci Computer
This model is currently in active use at Tygron.
* In Basic Mode the area dimension can be can approximately be 4-5 times larger.
Diplay Padding
Display resolution has large influence on the 3D Viewer performance. Therefor the 3D Viewer may be limited in size by grey padding around it. You can remove the grey padding by lowering your display resolution.
  • Low-end: systems with a HD display resolution (1920x1080) are limited with grey padding.
  • Medium: systems with a 4K UHD display resolution (3840x2160) are limited with grey padding.
  • High-end: systems with a 8K UHD display resolution (7680x4320) are limited with grey padding.
Multi-GPU systems
When the Tygron Client detects a system with multiple GPU's, such as an Intel processor's integrated graphics chip as well as a dedicated Geforce video card, you may be prompted to ensure the more powerful of the two GPU's is used to run the Tygron Client. Specific settings to configure this may vary per vendor. Keep in mind that some systems be also be configured to deactivate the more powerful GPU when running in a power-saving or low-battery mode. In these cases ensure that either the performance mode of the system is changed, or that the more powerful GPU remains available for the Tygron Client.
Virtualization
Virtual environments are currently not supported. The Tygron Client's 3D Visualization is one of its basic functionalities. To properly render a 3D environment as performant as possible, the software requires being run on a physical computer. Virtualization software (such as Citrix or VMware) is currently not supported, because the speed of 3D rendering is significantly reduced by virtualization, which abstracts direct access to the GPU, slowing the process of rendering the 3D environment.
Software
Video card Drivers
Please make sure you have the latest official drivers installed for your video card from the original manufacturer. In case you upgrade your videocard to a better one from a different manufacturere, please remove the old drivers before running the Tygron Geodesign Platform again. Not removing may result in the hardware check not recognizing your new video card, and thus the platform not starting.
NVIDIA
AMD ATI
Intel
Browsers
  • Google Chrome
  • Mozilla Firefox
Further explanation
Hardware
Because the Tygron Client contains a 3D Visualization, the various hardware requirements list above must all be met. A brief clarification of why each requirement is relevant:
CPU
The processor is the general "computing" part of a computer, performing most functions of a computer. General responsiveness and performance speed of the Tygron Client and the computer itself are (partly) dictated by the processor.
RAM
GPU
Often in the form of a video card, the graphical processor deals with all visualization matters. This component makes the 3D visualization of the Tygron Client possible. A better GPU can handle higher quality textures for more detail, better visualization of shadows, more generic trees in wooded areas and more fluent movements with higher frame rates.
Screen resolution
The number of pixels a computer screen physically has, usually indicated in the dimensions Width x Height (ex: 1920 x 1080). The Tygron Client requires sufficient screen space for panels that provide options for interaction with and inspection of a project's data.
Internet connection
Software
The ability to support the use of specific software can be based on a variety of decision. A brief clarification on the supported software:
Browser
