How to edit a Net Load
Revision as of 15:30, 28 February 2023 by Frank@tygron.nl (talk | contribs) (Created page with "{{Editor location|Net loads|Net load}} framed|left|The right panel for net loads in the editor. =====Name===== frame|right|The field for the "name". : ''The name of the net load. This is generally not visible to the end-user. You can change this by altering the text in the "Name" field.''<br clear=right> =====Net Type===== File:net-load-right-nettype.jpg|frame|right|The dropdown menu for the "network...")
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → Show Loads (Dropdown) → Net load
Name
Net Type
The dropdown menu for the "network type".
The network type this load belongs to. You can change this by selecting a different network type from the dropdown menu.
Is Root
The checkbox for whether this is a root load.
If this checkbox for "Is Root" is checked, this load is a root load. This means that this load is a producer in the network.
Time state
The dropdown menu for the "time state".
Whether or not the net load is connected, or in what step of the process this load resides. You can change this by selecting a different time state from the dropdown menu.
Building
The "Select Building" button, and the checkbox to disconnect from a building.
A load can be associated with a building. To do this, select "Select Building", and select a Building in the 3D Visualization. To remove the association with a building, uncheck the "Has Building" checkbox.
Node
The "Select Node" button, and the checkbox to disconnect from a node.
A load can be associated with a node. To do this, select "Select Building", and select a node in the 3D Visualization. To remove the association with a node, uncheck the "Has Node" checkbox.
Position
The "Set Position" button, and the checkbox to remove the override of its default position.
A load can have an explicitly determined position. To set its position, select "Set Position", and use the brush to select a location. To restore its position to the default location (or remove it from the project when the load does not have a default location, uncheck the "Set Position" checkbox.
