Map Type
The Map Type indication is a means to separate the Current situation with the Planned situation.
The values currently supported for maptype are:
Name Indication
CURRENT Current situation
MAQUETTE Planned situation
Items can be present in both map types at the same time. This is the case when starting a single, multi or test-run session. Once a stakeholder starts planning, upgrading and removing buildings, certain buildings will only be present in the maquette when planned or upgraded or only in the current situation when removed or upgraded.
The user interface of the Tygron Platform allows you to switch between the two Map Types to inspect the differences visually.
Generally, all aspects (logic, calculation, visualization) take into account that there are multiple situations, and therefore calculate and present these situations separate from each other.
