Net edit
Revision as of 13:22, 2 March 2023 by Frank@tygron.nl (talk | contribs) (Created page with "Net edit is an option in the editor that allows users to add, remove or replace Net Lines for networks using special drawing tools. These drawing tools are different from the usual selection drawing tools (brush). Draw options: * Add : Add a net line consecutively by adding net nodes and connecting the newest node with the previous one by adding a net line between them. Click on the same spot to stop the consecutive adding and to start somewhere else. : Ins...")
Draw options:
  • Add
Inserting a node into an existing net line is also possible. Snap distance is controller using the Merge distance (m) value.
Connect via roads will create a path from start to end using the road system.
  • Remove
Select a net line to remove, highlighted in red. With the option repeated selected, more net lines will removed until a net node is encountered that is connected to more than one other net line.
  • Move
Move existing Net Nodes and potentially merge them with other Net Nodes or split existing Net Lines.
