In order to improve the API we have made some changes:
2024.2.0 Update
- Improved consistency in asset image names. Indicators, Action Menus, Measures, Stakeholders, etc all have an imageName field instead of iconName, portrait etc.
- Overlay FUNCTION_HIGHLIGHT is renamed to FUNCTION and AREAS to AREA.
- Several unused Words have been removed.
- Renamed Overlay events SET_OVERLAY_REST_COLOR to SET_OVERLAY_REMAINDER_COLOR and SET_ICON to SET_IMAGE, SET_IMAGE to SET_OVERLAY_IMAGE.
2024.1.0 Update
- Zoomlevels (and related events) are not longer accessible via API, functionality was not used.
- All API calls now consistently default to the MAQUETTE version (when not in test run identical to CURRENT), this used to be mixed.
- New endpoints for 3D Tiles, Web Client heightmaps and viewers.
- Added security warning when accessing a Viewer with an API token instead of Stakeholder Web token.
2024.0.0 Update
- Location endpoint (api/session/location/) now defaults to the new 2024 API version.
2023.7.5 Update
- Added isActive boolean to Indicator endpoint, replaces deprecated active map.
- Editor/START_MAP_CREATION has "optional" additional value to set the area of interest.
- Editor/START_MAP_CREATION has option to change the CRS to something else then default EPSG 3857.
- Location endpoint has new version with additional information, defaults to old info.
2023.6.0 Update
User
2022
2023
GET_MY_HASH_KEY
GET_MY_LOGIN_KEY (rename only)
EditorScenario
Complete New event for setting scenario's
Removed
Following events are no longer needed and thus removed:
- EditorLevel (partly renamed to Scenario)
- EditorMessage (also endpoint api/session/items/messages)
- EditorContributor (also endpoint api/session/items/contributors)
- FacilitatorSession
EditorOverlay
2022
2023
ADD_CUSTOM_GRIDOVERLAY_LEGEND_ENTRY
ADD_LEGEND_ENTRY (rename only)
REMOVE_CUSTOM_OVERLAY_LEGEND_ENTRY
REMOVE_LEGEND_ENTRY (rename only)
SET_CUSTOM_OVERLAY_LEGEND
SET_CUSTOM_LEGEND (rename only)
SET_CUSTOM_OVERLAY_LEGEND_ENTRY_COLOR
SET_LEGEND_ENTRY_COLOR (rename only)
SET_CUSTOM_OVERLAY_LEGEND_ENTRY_NAME
SET_LEGEND_ENTRY_NAME (rename only)
SET_CUSTOM_OVERLAY_LEGEND_ENTRY_VALUE
SET_LEGEND_ENTRY_VALUE (rename only)
SET_ICON (new functionality)
SET_VISIBLE (new functionality)
2022
2023
SET_ACTIVE_FOR_STAKEHOLDER_AND_LEVEL
SET_ACTIVE_FOR_STAKEHOLDER_AND_SCENARIO (rename only)
EditorArea & EditorBuilding & EditorZoning
2022
2023
IMPORT
Added optional parameter to set the buffer
EditorGeoLink
2022
2023
New functionality
REMOVE_FUNCTION, SET_POINT_BUFFER, SET_LINE_BUFFER, SET_GEOMETRY_MODE
EditorGlobal
2022
2023
SET_READ_ONLY_START_VALUE
Removed, no longer needed
EditorIndicator
2022
2023
DUPLICATE_PERSONAL_INDICATOR
Deprecated, use DUPLICATE_INDICATOR
EditorLevee
2022
2023
New functionality
REMOVE_SIDE_FUNCTION, REMOVE_TOP_FUNCTION
EditorMeasure
2022
2023
New functionality
ADD_TIFF_SPATIAL, ADD_TIFF_POLYGONS, IMPORT_BUILDING_EXISTING_MEASURE, REMOVE_TIFF_SPATIAL, SET_AUTOMATIC_TIFF_POLYGONS, SET_GEOTIFF, SET_SPATIAL_TERRAIN_TYPE
SET_FIXED_WATER_STORAGE
EditorNeighborhood
2022
2023
SET_ACTIVE
Removed parameter to level.
EditorNetNode
2022
2023
SET_LOCATION
Added parameter to set the merge distance.
EditorSetting
2022
2023
New functionality
GET_SUN_AZIMUTH, GET_SUN_ALTITUDE, GET_SUN_MOTION, GET_EPOCH_TIME, SET_IMPORT_CRS
SET_FACILITATOR_TAB_ACTIVE, SET_COMMERCIAL_NAME, SET_VIEWFLOW_ACTIVE, SET_INTRO_IMAGE
Removed functionality
Check Setting for all types.
EditorStakeholder
2022
2023
SELECT_PREF_OR_FIRST_PLAYABLE_STAKEHOLDER
SELECT_STAKEHOLDER (rename only)
SET_PLAYABLE
SET_ACTIVE (rename only)
ADD_WITH_TYPE_AND_PLAYABLE
ADD_WITH_TYPE_AND_ACTIVE (rename only)
SET_DESCRIPTION, SET_INDICATOR_WEIGHT, SET_LEVEL_ASSIGNMENT, SET_LEVEL_BUDGET_INCREMENT, ADD_INDICATOR_WEIGHT
EditorTime
2022
2023
SET_NUMBER_OF_PAUSE_MOMENTS, SET_SESSION_DURATION_HOURS, SET_SIM_TIME_TYPE, SET_SIMULATION_DURATION_YEARS
EditorUpgrade
2022
2023
SET_CONSTRUCTION_TIME_MONTHS
EditorNetCluster
2022
2023
SET_LEVEL
SET_SCENARIO (rename only)
Answer
2022
2023
DELETE_MESSAGE, MEASURE_ASK_DEMOLISH_DATE, MEASURE_DEMOLISH_APPROVAL, WATER_ASK_APPROVAL, WATER_CONFIRM
Removed, no longer used
Client
2022
2023
MESSAGE_ANSWERED, MESSAGE_MOTIVATION_ANSWER
Logic
2022
2023
BEAMER_SET_OVERLAY_ID, BEAMER_SET_OVERLAY_DIFFERENCE, BEAMER_SET_SCORE_PANEL, BEAMER_SET_VIEW, BEAMER_SWITCH, MEASURE_UPDATE_CUSTOM, MESSAGE_ACTIVATE, MESSAGE_RESET, MESSAGE_REVOKE, SETTINGS_ALLOW_INTERACTION, SETTINGS_SET_ALLOWED_WATER_LEVEL_INCREASE, SETTINGS_SET_MESSAGE_AUTO_RESPOND, SETTINGS_TEAM_NAME,TIME_SET_SIM_MULTIPLIER
LEVEL_SET_ACTIVE
SCENARIO_SET_ACTIVE (rename only)
Participant
2022
2023
LOAN_ACTIVATE, LOAN_NEW, MEASURE_CREATE_CUSTOM, MEASURE_PLAN_DEMOLISH, MEASURE_SET_WATER_CLASSIFICATION, MESSAGE_ANSWER, MESSAGE_ANSWER_WITH_MOTIVATION, MESSAGE_NEW, MONEY_TRANSFER_ASK
