Version 2024.5.0
Revision as of 15:41, 27 October 2023 by Frank@tygron.nl (talk | contribs)
Version 2024.5.0 is released on preview.tygron.com on October 27th 2023.
Project Loading
- Improved elevation map loading for extreme resolutions, e.g. 10cm.
- Fix elevation artifact in water (squares visible).
- Basic map is now available for all domains.
Overlay
- Ground Water: Added prequels for CONDUCTIVITY and BOTTOM_DISTANCE.
- Heat: Added prequels for BUILDING_ELEVATION and TERRAIN_ELEVATION.
- Improved Overlay Overview panel.
- Bugfix for extreme values in Waterwijzer landbouw.
- Improved feedback on edited Attributes with option to revert to default.
- Added support for importing GeoTIFF larger then 2 billion cells in project.
Indicator
- Documented Indicator's exact score and exact text options
- Fixed issues with displayed indicator scores and explanations (Current and Maquette)
Measures
- Areas can now more easily be (de)activated by Measures.
Other
- Improved API by removing sometimes useless domain argument.
- Improved visualization of roof models.
- Improved uncommitted map selection in Editor.
- Added Geo Plugin function color to DXF export.
- 3D web-viewer supports cinematics via action menu event bundles.
- Keep-alive is now by default enabled for new projects.
- Improved UX by adding primary and secondary buttons.
- Fixed some overstretched panels in the viewer UI
- Based on Java 21 LTS for increased performance, security and stability.
- Fixed issue in GeoShare Viewers where some polygonal features were missing.
- Several smaller bug fixes and WIKI updates.
