Install
- An installer is a software component used for the installation, maintenance, and removal of the Tygron Engine software.
What is the function of the the installer in relation to the Tygron Engine?
- The Tygron Engine is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
- Before you can install the Tygron Engine you first need to download the installer.
How to install the Tygron Engine:
- Open your browser
- open http://beta.tygron.com/
- Select "New Tygron Engine 2.0"
- Select "Download Windows (64 bit) Installer
Select 3D World
Select Constructions from ribbon bar
Select desired construction type
Select 'Add' from the bottom of the list
Newly added default building
