Install
Revision as of 13:15, 7 August 2015 by Joris@tygron.com (talk | contribs) (→Logging onto the Tygron Engine)
What is an installer in relation to the Tygron Engine?
- An installer is a software component used for the installation, maintenance, and removal of the Tygron Engine software.
What is the function of the installer in relation to the Tygron Engine?
- The Tygron Engine is an application which needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup.
Downloading the installer
- Before you can install the Tygron Engine you first need to download the installer.
How to Download the installer for the Tygron Engine:
- Open your browser
- open http://beta.tygron.com/
- Select "New Tygron Engine 2.0"
- Select "Download Windows (64 bit) Installer"
- "TygronEngineWin64.msi" will start downloading
- Once the download has been completed proceed to the next step, "Running the installer"
- Before you can use the Tygron Engine you first need to run the installer.
How to Install the Tygron Engine:
- Open "TygronEngineWin64.msi"
- the installer will install the Tygron Beta Application
- A desktop shortcut and a start-menu shortcut will be created
1. Application being installed
2. Installing succesfully completed
3. The desktop shortcut to be used to launch the Tygron Engine
Launching the Tygron Engine
- Once the installer has completed you can launch the Tygron Engine Beta application.
How to Start the Tygron Engine Beta Application:
- Launch "Tygron Beta Engine" from the desktop shortcut or the start menu
- You will be prompted with the login screen.
- Once the Tygron Engine Beta application has been launched, you will be prompted with the login screen.
1. Login screen, presented when Application has been launched
