How to open the Project Sources panel
Revision as of 12:17, 30 January 2024 by Frank@tygron.nl (talk | contribs)
How to show the project sources panel:
  1. Select in the editor Current situation
  2. Hover over 'Geo Import' from the ribbon bar
  3. Select 'Show Project Sources'
The project sources panel shows the used Sources in the project, such as Geo data sets, as well as data imported by users. Also, an explanation on what is in the datasets and the possibility to rename/remove a WFS or CSW connection can be done here.
The sources are divided in three categories:
  • Catalog Services
Here are the by default available CSW connections in the Geo Data Wizard visible. Also CSW connections added by a user are listed here.
When a user adds a CSW connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
  • Default Sources
  • User Sources
  • Web Services
Here are the by default available WFS connections in the Geo Data Wizard visible. Also WFS connections added by a user are listed here.
When a user adds a WFS connection, the connection can be removed from the list or it is possible to edit the URL, name and other information in the panel on the right.
