How to select a GeoTIFF
Revision as of 16:07, 30 January 2024 by Frank@tygron.nl (talk | contribs)
GeoTIFF Manager.
For some components in the Tygron Platform a GeoTIFF can be selected as (input) data.
How to select a GeoTIFF:
  1. Select the option to select or use a GeoTIFF, for the applicable component. This will open the GeoTIFF Manager.
  2. If the GeoTIFF you wish to use is not yet loaded, select the "Import new GeoTIFF" option, and select the desired GeoTIFF.
  3. In the GeoTIFF Manager, select the GeoTIFF you wish to use.
  4. Select "Apply".
  5. The GeoTIFF is now used as data or input for your component.
