Template:Howto
If more are needed, add:
-->{{#if:{{{20|}}}|{{{form|:#}}} {{{20}}}}}<!--
Example:
Howto:
- First include the template.
- Then write instructions.
- The title will automatically be the page name.
How to add a custom title:
- Then add a "title" parameter, which will be prefixed with "How to".
- Finally, write instructions.
Setting up other parameters:
- Include the template.
- Use a "preamble" parameter, which will replace the default "How to".
- Use a "title" parameter, which will be prefixed with the entered prefix.
- Use a "form" parameter to dictate the listing prefix (":#" is default, "::*" for indented unordered list.
Use a "howtoblock" to:
Add multiline instructions
Use an "image" for those instructions.- Finally, review the result.
The template can be generated using javascript by executing the following function in javascript ((deprecated, needs to be updated):
var steps=20; var string="<!--"; string=string+"\n"+ "-->{{#if:{{{file|}}}|<div class='editor_steps_box_wrapper'>}}"; string=string+"\n"+ "<div class='editor_steps_box'>"; string=string+"\n"+ "<div class='editor_steps_header'>"; string=string+"\n"+ "<div class='editor_steps_title'><span>'''{{{preamble|{{#if:{{{title|}}}|How to|{{PAGENAME}}}}}}}{{#if:{{{title|}}}| {{{title|}}}|}}:'''</span></div><!--"; string=string+"\n"+ "-->{{#if:{{{video|}}}|<div class='howto_video'><span class='video_text'>Watch the video: </span>[[File:YoutubeLogo1.jpg|link={{{video|}}}|frameless|right|75px]]</div>|}}<!--"; string=string+"\n"+ "--></div><!--"; string=string+"\n"+ "--><div class='editor_steps_content'><!--"; string=string+"\n"; for(i=1;i<=steps;i++) {; string=string+"\n"+"-->{{#if:{{{"+i+"|}}}|{{{form|:#}}} {{{"+i+"}}}}}<!--"; } string=string+"\n"+ "--></div><!--"; string=string+"\n"+ "--></div><!--"; string=string+"\n"+ "-->{{#if:{{{file|}}}|<div class='editor_steps_image'>{{{file|}}}</div></div>}}<!--"; string=string+"\n"+ "-->"; console.log(string);
