How to calculate the hourly wind speed
The hourly wind speed from the KNMI weather data table column FH has to be divided by 10, since it is defined in 0.1 m/s.
| Column | Name | Unit | Dutch Description |
| 2/B | YYYYMMDD | Date | datum (YYYY=jaar,MM=maand,DD=dag) |
| 3/C | HH | Hour | tijd (HH=uur, UT.12 UT=13 MET, 14 MEZT. Uurvak 05 loopt van 04.00 UT tot 5.00 UT |
| 4/D | DD | Degrees | Windrichting (in graden) gemiddeld over de laatste 10 minuten van het afgelopen uur (360=noord, 90=oost, 180=zuid, 270=west, 0=windstil 990=veranderlijk. Zie http://www.knmi.nl/kennis-en-datacentrum/achtergrond/klimatologische-brochures-en-boeken |
| 5/E | FH | 0.1 m/s | Uurgemiddelde windsnelheid (in 0.1 m/s). Zie http://www.knmi.nl/kennis-en-datacentrum/achtergrond/klimatologische-brochures-en-boeken |
- The values at each hour regard the measurement over the preceding hour up to that time. To obtain the value for 12:00 UTC, the values at 12:00 UTC must be used.
- The wind speed (hourly, and daily average) can also be based on an other data source; Potentiele wind (UP): http://projects.knmi.nl/klimatologie/onderzoeksgegevens/potentiele_wind-sigma/. These values are often a few 0.1 m/s higher than the values from the historical KNMI weather data table.
