Template:Drainage variants reference
Revision as of 17:15, 11 December 2024 by Frank@tygron.nl (talk | contribs)
Drainage can be:
- Passive Drainage lets water flow from the drainage pipes into the waterway.
- Active Drainage with a negative Q can pump water from from the waterway (with a lower level) into the drainage pipes.
- Active Drainage with a positive Q can pump water from the drainage pipes up into a waterway (with a higher level).
