How to adjust a Neural Networks metadata
Revision as of 15:03, 19 December 2024 by Frank@tygron.nl (talk | contribs)
Metadata of a Neural Network stored in the ONNX file format can be adjusted using the python code found below.
Prerequisites
An installed python environment is required to execute the code. Additionally, install the onnx library using PIP:
pip install onnx
To add or edit a metadata key (without duplication), you can use the following code:
def addMeta(onnx_model, key, value): for entry in onnx_model.metadata_props: if entry.key == key: entry.value = value return meta = onnx_model.metadata_props.add() meta.key = key meta.value = value
To adjust an existing ONNX file, you first have to load the model. Next, pass the model to the method, with additional key and value arguments.
import onnx onnx_model = onnx.load("path/to/onnx/file") addMeta(onnxModel, "key", "value")
Lastly, save the onnx model again to a (new) file:
with open(onnxFilePath, "wb") as f: f.write(onnx_model.SerializeToString())
Producer, version and description are set using these functions, as these are not stored in the meta data.
def setProducer(onnxModel, producer): onnxModel.producer_name = producer def setModelVersion(onnxModel, modelVersion): onnxModel.model_version = modelVersion def setDocString(onnxModel, description): onnxModel.doc_string = description
