File Menu
Revision as of 11:22, 12 August 2015 by Joris@tygron.com (talk | contribs)
Selecting the "File" Tab opens the File Menu properties window. This window provides access to detailed project information and properties of your project. The menu on the left side provides access to: Details, Versions, Save, Save As and Exit.
By default the "Details" menu item is selected.
The white arrow on top takes you back to the main view of the editor.
File Pane
File Pane
Details
The Details Panel provides access to project specific characteristics and details.
Project Name
The Details Panel provides access to the name of your project, as provided by the user when initially creating the project.
Details
Bottom panel
Bottom panel
Playable Stakeholders
The number of playable stakeholders for your project.
Language
The language selected for your project, as provided by the user when initially creating the project.
Currently available Languages: EN / NL
Map Size
The current map size of the project. The map size can be displayed in meters or in feet (m or ft). The Map Size was selected when initially creating the project.
Available map sizes range from 250m x 250m to 3.000m x 3.000m
Location
The location of your project, described in X, Y coordinates (What coordinates system is this?).
Unit System
The current active Unit System. The Unit System .. which units are being used to display measurements. The Unit System was selected when initially creating the project.
Available unit systems: Customary (feet), International (metric), British Imperial System
Currency
The current active Currency. The Currency was selected when initially creating the project.
Available currencies: US Dollar ($), Euro (€), British Pound Sterling
Edit Rights
Bottom panel
Bottom panel
The Edit Rights properties describe which users can access and edit the currently opened project.
Owner
The Owner is the user initially creating the project, often the e-mail address of the user.
The dropdown-listbox next to the user provides access to the parameters "Write" and "Read". This makes it possible to make your project read-only.
Other users in domain
Users are grouped inside a domain, a domain can consist, for example, out of people from the same organisation.
The dropdown-listbox next to the domain provides access to the parameters "None" and "Read" and "Write". This parameter controls if users inside your domain have access to the selected project and if they have read-only access, or can also write (save) the currently selected project.
Public (no account required)
File Pane
File Pane
This parameter provides access to the public availability of the game. If the selected parameter is set to "None", the project is not public. If the selected parameter is set to "Read", the project is public.
When the public parameter is set to "Read", a URL will be generated, which will appear below the "Keep Editor Session Alive" parameter. The "Keep Editor Session Alive" must be checked to make a public game accessible.
Keep Editor Session alive for one week after last user exit:
In most cases, an Editor Session is only alive when there are users connected to a session. Sometimes, you want a session to be active, without anyone being connected all the time. This means a user in a different timezone for example can join this active session. You don't have to keep your own computer connected to the session at all times in this way.
Versions
File Pane
File Pane
Versions assist users in saving different versions of a certain project, instead of having to save to a different filename everytime.
The table displays a list of Versions available for this project. The table has 3 colums: Version, Text and Active. The "Version" column displays a linear number, the Text column displays the text as input by the user in the "Description" Field. The "Active" Column displays "Active" next to the Version row which is active.
The current project has 3 versions are available: 0 (Base Version), 1 (Version of 12 Aug 2015) and 2 (Version 2). Version 2 is the version which is active, as displayed in the "Active" column.
Switching Versions
You can revert to an old version by closing the Project and switch versions in the Main Menu.
"Main Menu" -> "Options" -> "My Account"
Save
Pressing "Save" saves your project data. A spinner will appear indicating that the project is saving. When succesfully saved the spinner will disappear and the screen will indicate a successful save message.
"Project ... was successfully saved"
How to save your project:
  1. File -> Save
  2. Spinner appears
  3. Confirmation message
Save As
Pressing "Save As" facilitates users in saving the project with a new name.
The same restrictions apply when creating a new project, between 3-15 characters.
Exit
Pressing the exit button exits the Application.
File Pane
A popup-message is being displayed asking the user if he would like to save his project. Pressing "Yes" saves the project and exits the application, pressing "No" exits the application without saving the project.
