Gpu cluster index (Grid Overlay)
Revision as of 14:39, 14 October 2025 by Rudolf@tygron.nl (talk | contribs)
Adding GPU_CLUSTER_INDEX=1 as an attribute to any Grid Overlay will force the overlay to be calculated on the GPU Cluster with index 1. The index of each GPU cluster is visible in the Calculation panel.
This attribute can be useful to always force a heavy calculation onto a SUPER cluster. Or to test performance on different clusters.
  • Over time new GPU Cluster may be added or removed, this can change the cluster index value.
  • When a cluster cannot run this specific overlay, for example due to insufficient memory an error will return.
