How to edit the Sun angle
Revision as of 11:18, 29 October 2025 by Maxim@tygron.com (talk | contribs)
How to edit the Sun angle:
  1. To adjust this date and time, first select tools in the ribbon bar.
  2. Next, hover over environment, and select the "Adjust sun angle" option.
  3. Once loaded, this panel allows you to provide a date and hour of day for your project. Based on this date and hour, the altitude and azimuth angles will be calculated to reposition the sun in the 3D visualization.
  4. Click on the calender icon to adjust the date.
  5. While adjusting the hour of day, you can inspect the 3D visualization to see directly what shades are created at that time of the day.
  6. To save a certain date and hour of day, click on the Save Angle button. When re-opening your project in the future, the sun should be located at that same position in the sky.
