| Icon |
Key |
Unit |
Range |
Description |
Default value |
UPPER_THRESHOLD |
m + datum |
-10000 to 10000 |
The threshold of the higher end-point of the pump. Water flows from the lower end-point to the higher end-point until the water level at the higher end-point has reached the threshold. If not selected, the Upper Threshold will be ignored as a mechanic. |
None |
UPPER_THRESHOLD |
m + datum |
-10000 to 10000 |
If an upper threshold is set, water will only flow out of the model through this inlet until the water level at the point of this Inlet is equal to or less than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. |
None |
