How to add the Hydrologic System Overview plugin
The Hydrologic System Overview is a dashboard created to analyze results of a Water Overlay calculation. For each Water Level area identified by the Water Overlay a dashboard instance is created. The follow how-to describes the steps required to install this dashboard. This installer can be found on the Public Share, under Plugins.
How to add the Hydrologic System Overview plugin:
- Select Current Situation in the ribbon bar
- Hover over Panels and select Find more in Public Share
- Navigate to Plugins
- Inspect the file named hso.txt
- Click on the import button
- Select the option Import Text Panel in the File Handler panel.
- The installers opens in the viewer panel with the title "hso"
- Follow the steps to install the HSO
- Once finished, an instance of the Hydrologic System Overview will open.
Find more on Public Share option found in the Panel Popup.
The Hydrologic System Overview installer found on the Public Share.
Importing the installer as a new Text Panel.
Installer opening message shown when opening the imported text panel.
Recalculating the project after installing the required components for the dashboard.
Instance of the HSO Dashboard for the added Water Level Area.
